Results 1 to 7 of 7
    Feb 2019
    Default Kess V2 problems writing BMW MSX
    Hello friends
    I have a EU clone Kess V2, it reads MSV80 and MSD80 through OBD without any issues but when I write to another used DME, it writes fine but corrupts HW and SW. The car cranks and won't start. Does anyone know why? Is it possible to fix a DME that has FFFF where software and hardware is?
    Dec 2015
    Brazil_Minas Gerais
    Essa ECU não aceita clonagem, precisa escrever os dados no CAS.
    Feb 2019
    Quote Originally Posted by CHAVCAR View Post
    This ECU does not accept cloning, you need to write the data in the CAS.
    So there is no way to properly clone these DMEs? The only way is to write the DME ISN to CAS?
    Newbie TOM8O's Avatar
    Jul 2017
    Stoke-on-Trent
    I'm doing them only in that way
    bearheroes's Avatar
    Dec 2011
    You can’t clone via obd...can’t even read whole file...isn is in password protected area...that’s why car will never start...also msd can’t be cloned on msv or vice versa...
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  6. The Following User Says Thank You to bearheroes For This Useful Post:
    looneyman (14th July, 2019)
    Feb 2019
    Quote Originally Posted by bearheroes View Post
    Thank you. I wish I have known that before reading and writing MSD80 to MSD81. I won't be using Kess V2 anymore with these DMEs.
    Is it possible to repair the MSD81? Do I find a good flash and write it with another tool? Or is the DME not repairable now?
    bearheroes's Avatar
    Dec 2011
    Try to find good files to write...if not work then you need to do it with boot mode or with winkfp expert mode.
  9. The Following User Says Thank You to bearheroes For This Useful Post:
    looneyman (15th July, 2019)
