Results 1 to 8 of 8
    Mar 2016
    Default VW Login Pincode Retrieval
    Hello, I have a used 2000 VW Beetle TDI instrument cluster that I would like to retrieve the login PIN in order to adapt to the vehicle. If anyone with VAG software could find it in the dump for me, I would appreciate it. Also, if you are feeling kind, I could use 168,000 miles instead of 229,500....
    Nov 2016
    Try 01594 and report
  3. The Following User Says Thank You to Stopro92 For This Useful Post:
    morrisgauge (11th July, 2019)
    Mar 2016
    01594 = Login Failed
    I would note that I am using a Launch X431 with most current software, I will not have access to a VCDS for a few days.
    Nov 2016
    You have immo II or III?
  6. The Following User Says Thank You to Stopro92 For This Useful Post:
    Mar 2016
    The cluster is out of a 2000, going into a 2001. I believe they are both immobilizer 2.
  8. #6
    Nov 2016
  9. The Following 2 Users Say Thank You to Stopro92 For This Useful Post:
    jomberykaso (11th July, 2019), morrisgauge (11th July, 2019)
  10. #7
    Mar 2016
    Your PIN is correct, used the X431 to adapt instrument cluster and relearn key. It was IMMO 2. Thank you kindly, you saved the day.
  11. #8
    Mar 2016
    In case anyone needs it here is the final dump with 165,690 miles. Pin code is 01594. Note that VW has immobilizer timeouts and you may have to walk away from adaptation for an hour or so. I was able to adapt with a basic Launch X431 Diagun V.
