Results 1 to 9 of 9
    Jul 2016
    anywere
    Default clear crash 68346715 AB RAM 4DOOR
    CLEAR CRASH RAM 2018 4DOOR EPROM 95256 READ UPA not have orc occupant restraint controller
    someone will have a solution please
    Last edited by chez1; 16th July, 2019 at 02:52 PM. Reason: i forget put year of truck
    You could try this, its a virgin file , number is slight off but you need to lock it with witech, pass in pm
  3. The Following User Says Thank You to dzienciol For This Useful Post:
    karzan1977 (30th March, 2021)
    Jul 2016
    anywere
    try and report backˇˇ
    Jul 2016
    anywere
    IMG-20190715-WA0036 (1).jpg not work thanks
    DK Veteran buga37's Avatar
    USA
    Quote Originally Posted by chez1 View Post
    You need a new or used module, i've had the same issue
    Mar 2018
    Hello, the same problem, witech 17.04.27 not working with this car, how to lock this SRS module?
    Apr 2012
    Saudi Arabia
    i need the file plz i lost the file not able to download
    Read The Rules Mate !!
    Jan 2020
    Canada
    if this helps, not exact same but close, its from working vehicle
  10. #9
    Mar 2017
    Default need clear the crash
    I test the virgin solution for the member dzienciol , but not work... because his dump is belong 68346721 , but my module is 68346715...
    the module 68346721 has occupant but the module 68346715 not have
    occupant restraint
    kindly anyone can help to get right solution to clear the crash?
    thanks for dziencio for his try help.
