Results 1 to 4 of 4
    Jul 2019
    Default corsa d (life) interior light
    Hi does anyone know if the interior light on a corsa d is controlled by the BCM? on my my lads car the light in the luggage area at the back works fine but the interior light does not, i have checked the bulb and f9 in the fusebox and both are ok. using a meter there seems to be no power to the light fitting so is there another 'hidden' fuse somewhere that i dont know about? it just seems strange that the luggage light works and the inside light doesn't. thanks.
    Jul 2016
    Vilnius
    Maybe you have wire chaffing issue inside the door's boot? I found this problem recently...
    Try to open ALL the doors and see if the light still doesn't come on.
    Also, if in doubt undo the boots to check the door wires for damage (the round plastic thing should just be pushed or pulled, I don't remember)
    * MK100
    kadett90's Avatar
    Mar 2017
    If you measure voltage in interior light gray/yellow or gray/white lead and you don't have voltage there is broken lead between fuse 9 and interior light.
  4. The Following User Says Thank You to kadett90 For This Useful Post:
    alerton (18th July, 2019)
    Jul 2019
    thanks i will check that at the weekend,,,,,,,, IF i can get the lad to stop driving it around for long enough, 2 weeks passed his test and he still didnt get bored of driving
