Results 1 to 2 of 2
    Jul 2019
    Default corsa d (life) interior light
    hi does anyone know if the interior light on a corsa d is controlled by the BCM please? on my lads corsa d the luggage compartment light works fine but the interior light does not, i checked the fuse (f9) and the bulb and they are ok. using my meter there seems to be no power to the light fitting so is there another 'hidden' fuse i dont know about? it just seems strange that the luggage light works and the inside light doesn't. thanks
    Meat-Head's Avatar
    Try swapping bulbs over as often modern cars see a fault and shut down output
    often negative switched
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    alerton (18th July, 2019)
