Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    Dec 2016
    Quote Originally Posted by patrickmk3 View Post
    my friends thank you very much with your help i made it a succes
    of course , everybody can do this job with old tool , cheap tool , on table ....
    this is the old BSI ! old ID48key !
  2. #17
    Jun 2019
    Quote Originally Posted by TERMINATOR1000 View Post
    you're wrong its ID46 PCF7946 marelli remote, see you don't know everything... if you have proof you can do CNG with your obdtool make a video and why not reply 1 year ago when i made this topic?
  3. #18
    Jan 2020
    hi again,
    i read the chip so know i have the pin and i try it is correct.
    but than i wanted to make transponder id46 pcf7946 with effi because i want remote key.
    effi write transponder but than the file for eeprom it save is all 00
    so thats not working for me or i do something wrong ?
    than autel read the immo data but its not correct some data is and some data is not.
    than i put read of upa in autel tool and it give me data error so thats not possible to.
    now at this moment i am trying to make dealer key with lonsdor.
    i put the bin file i made with upa of eeprom on lonsdor and will try if it than can make a dealer key sucsesful.
    * ok i tryed that now lonsdor make key sucsesfull.
    but it give me to option:
    pcf7946 (8pin)
    pcf7946 (10pin/16pin)
    i am using vvdi chip xp27 so i dont think it will make a differance but i will post the result.
    little bit more info:
    old key is 8 pin so i will use that.
    lonsdor can read data correctly i believe because after i generate dealer key it give me the correct pincode to.
    so the way i see it now is read data of bsi with programmer.
    than use empty pcf7946 transponder for key with remote and pcf7936 for key without remote.
    than put the bin file you read with programmer on lonsdor and make a dealer key.
    and than program true obd.
  4. #19
    Jan 2020
    well it almost worked.
    the dealer key i made with lonsdor i could not program it with lonsdor to the car.
    but with autel im608 i can program it to the car.
    only problem is old remote 3 button all correct.
    new remote 3 button
    button open is trunk
    button trunk is trunk
    and button close dont do anything.
    this was with vvdi key for magnetti bsi.
    tomorrow wil try KD key.
    both not work than maybe lonsdor dont do it correct
  5. #20
    Jun 2019
    new remote 3 button
    Dont use effi, cracked effi has lots of bugs.
    You need to precode remote for smd thats on the new remote not old remote most have 10 pin smd on chinakeys, lots have been written on this already search forum.
  6. #21
    Dec 2016
    Quote Originally Posted by Staafonline View Post
    No you're wrong , id 48 or id 46 all tool can do it in 2 minutes , particularly Lonsdor , this topic is simply an newbie joke , and everybody jump !!!!!!!!!!!!!!!!!
    jump !!!!
  7. #22
    Jun 2019
    jump !!!!
    Man you're making a fool of yourself again and probably never worked on a Ducato 250 CNG. Instead you should actually help and give advice, not insult. Oh for you information Lonsdor never worked on ducato CNG no precode, no pincode no, program key if it did that would have made my life so much easier. Have a lot of cngs came in here because others wont touch it, because no comms on OBD
  8. #23
    Dec 2016
    obd2 is on BSI , why don't com ? Yes you'r wright , i use I-O terminal & never fail + Multiecuscan . I use Lonsdor only for fast job ...
  9. #24
    p1et's Avatar
    Oct 2013
    Terminator with all due to respect, you were wrong saying it's ID48 and you should better just correct your mistake instead insulting and teaching others.
    And now, please everyone chill and have a nice weekend
  10. #25
    Dec 2016
    Quote Originally Posted by p1et View Post
    hello , all is OK , yes i said bullshit ...
  11. #26
    Mar 2018
    UK
    new remote 3 button
    Few people reported that XH Marelli doesnt work corect
    I think that KD also can't work
    Buy quality key with real PCF7946 and maybe will work with your tools
  12. #27
    Jan 2020
    Quote Originally Posted by Manta1600 View Post
    yeah indeed.
    i tryed xh and kd now and both not correct.
    i used xh before on many citroen jumper but for this one it doisnt work well.
    i will order some original keys for this car.
  13. #28
    Jan 2020
    hello every one i wanted to give some feedback.
    some days ago i worked together with engineers of vvdi and lonsdor and autel.
    the vvdi keys for marelli can now work on cng version.
    also autel im608 can make the dealer key with sucses now the same for lonsdor.
    all options work now.
    read and write eeprom true obd with autel im608 annalyse data is already correct pin now and key ids on correct position.
    maybe some one will benefit from this information in the future thats why i wanted to add it to the topic
    for lonsdor the update is already there.
    for autel it will come soon i think because i have beta version now but i inform them already it worked correct so everybody should get the update soon i think.
    greetings patrick.
  14. The Following 3 Users Say Thank You to patrickmk3 For This Useful Post:
    lion0304 (2nd February, 2021), Staafonline (7th February, 2021), Weasel3 (2nd February, 2021)
