Results 1 to 11 of 11
    Feb 2012
    Default renault kangoo 2002 immo off sirius 32 c
    hello
    pls i need tested immo off for ecu siemens sirius 32 with working A/C
    the ecu
    S 110030306 C
    the original data some one erase it
    thanks in advanced for help
    tazz75's Avatar
    Nov 2018
    Engine ?....1.6 16V?
  3. The Following User Says Thank You to tazz75 For This Useful Post:
    king alie (16th July, 2019)
    Feb 2012
    8 valve
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Did have a look here:
    https://www.digital-kaos.co.uk/forums/showthread.php/431661-immo-off-kangoo-1-4-8V-ECU-siemens-siruis-32-S110030306-C
    So if it is the one you need, here is the off:
    Greetings,
  6. The Following User Says Thank You to Louislesinge For This Useful Post:
    Feb 2012
    Hello
    Yes it is the same
    Thanks I 'll try and report
  8. #6
    Feb 2012
    Hello
    Do I need to cut any wire
    The immoplizer is out
  9. #7
    Jun 2017
    French Jungle
    If you removed the immo box don't nedd to cut wire. ,If it is on car, cut line 58.
  10. The Following User Says Thank You to Louislesinge For This Useful Post:
  11. #8
    Feb 2012
    Hello
    The car is away and need work on the fueil system
    But the spark plug is working
    It means the car ecu is immo off 100%
    Thanks for help again
  12. The Following User Says Thank You to king alie For This Useful Post:
    mohamed maila (23rd March, 2022)
  13. #9
    Dec 2015
    please password
  14. #10
    belgrade,serbia
    send your file we will do immo off
  15. The Following User Says Thank You to vladanr For This Useful Post:
    PierreTheron (24th March, 2022)
  16. #11
    Aug 2023
    Hello,I need password too and instruction,I am new in this busines
