Mpps and galetto read and write without problem edc16c34 from focus
Galletto is more stable.
If is 2010 is euro 5 model and you will not be able to read by obd.Only bdm
FILE SERVICE
REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agricultureGenuine WinOLS user
I don‘t have experience with Galletto but writing this ecu with MPPS will definitely F..K your ecu.
Sent from my iPhone using Tapatalk Pro
Calm down, If you flash will erase you write something from net and car start, some time ago I write different dumps from other focus and on 20 dumps, 16 working, but sometimes was faults.
All by OBD and galetto.
Mpps v18 I used too and all ok.
When flash is corrupted , he can not write any other flash dump , because ECU will not respond on OBD. And yes, he must open the ecu and write it over BDM
It all depends the sw version, make id with your galleto clone and post here. If not safe thru OBD you can BDM it with your galleto.
Even genuine tools sometimes need to BDM this ecu
AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
FULL SWIFTEC AND EVC RESELLER
FILE SERVICE FROM 8AM - 9PM 7/7
BAPRO 4WD DYNO
dont try this ecu with mpps v13 clone
