use terminal, read pin from new ecu, the same tool read yours pin from bcm. Use mdi, reset new ecu and learn his to car and car started.
Ok so few weeks ago i posted on there about cloning the delco e78
As advised by a member or 2 i committed with IO Terminali
So i can read the emulated eeprom and flash of the donor ecu and shadow password no issue bench or OBD
The original ecu powers up but fails on the CAN so i thought hmmmm bootpin recovery only you need the shadow password to read it in recovery
So my question is as follows .
Whats the best way forward to get the car running with donor ecu and any suggestions on reading data on original
Original BCM untoched info
BCM TYPE : DELPHI 70F3379+93C86
Vehicle Identification (VIN) : W0L0SDL08E4207465
System Supplier ID : DELPH0400
System Name or Engine Type : BCM4400
End Model Part number : 13424260
Supplier ECU hardware number : 28372268
Software module 1 ident. : 1398222904
Software module 1 ident. Alpha Code : HE
Software module 2 ident. : 540356151
Software module 3 ident. : 842543927
Software module 4 ident. : 1196240945
Software module 5 ident. : 842543409
Software module 5 ident. Alpha Code : GM7
Hardware Key Number : 72SAPG *
Programming Date : 20100401
Mics. module ident : 8F67
And donor attached files
FILE SERVICE
ive not got mdi :-(
