dtc off not work, must edit maps with flaps than dtc gone.
Hello
i need help for delete DTC Codes. P1109 P1110
i tested solucions attached,but not work.
i need inlet flaps and dtc codes erased...
Help me please.
Chiptunning all stages
Egr. Fap/DPF. Torque Monitor disable. CVN Bypas
DTC removal. AdBlue . Hot Start Fix. Speed Limiter. Lambda remove.
MAF remove. TVA remove. Flaps/swirl flaps
FILE SERVICE
any help me?
Try this solution.
If i helped, don't forget push thanks + rep
saxomania (16th July, 2019)
here it is try
Cheers man
