Results 1 to 4 of 4
    Aug 2015
    Default [SOLVED]Corsa D 1.2 16v too rich no error codes
    hi,
    i have problem witch petrol corsa D z12xep,
    it works on way to rich mixture, and has no stored errors,
    MAP sensor reading looks wrong, at idle sometimes it is around 75 kpa, sometimes 101kpa,
    sensor was replaced but nothing`s changed,
    temp sensors, lambda looks fine,
    intake manifold is checked, and there are no leaks.
    Any ideas would be great!
    Thanks in advance!
    SOLVED
    It was a timing problem
    it seems that wrong type of timing chain lock was used,
    after changing timing car works fine
    Meat-Head's Avatar
    Fuel pressure too high, what color are the spark plugs? Really black?
    Jul 2013
    yorkshire
    Check mass air flow sensor and trunking for unmetered air.
    Aug 2015
    Quote Originally Posted by autoden View Post
    car is not equipped with one, we checked for leaks and found nothing,
    I will check pressure, the plugs are black but not like pitch black
