Page 1 of 3 123 LastLast
Results 1 to 15 of 38
    Oct 2015
    GER
    Default Siemens MS42 Immo Off Guide [00110AD, 00110C6, 00110C7, 00110CA]
    Hi mates,
    I recently put some effort into the disassembly of the MS42 and ported the public available EWS delete / Immo Off / Immo delete to other software versions, because there is only junk around at the moment.
    YOU NEED THE FULL 512KB BINARY FOR THIS, CALIBRATION OR TUNE FILE WILL NOT WORK!
    This modification works for software versions 0110AD, 0110C6, 0110C7 and 0110CA. If the demand is high enough, I can take a look at others as well.
    To determine the version you have, open the binary and look at 0x48040, it starts with "ca" and folled by the version string.
    No look at the following patches. go to the specified HEX location and replace the original code with the EWSdel.
    ca0110AD.DAT
    HEX location: 0x26A0C
    Original 88 90 88 60 8A 0D 02 80 EA 00
    EWS del DA 07 68 28 8E 0D BE 0D DB 00
    ca0110C6.DAT
    HEX location: 0x283BA
    Original 88 90 88 60 8A 0E 02 F0 EA 00
    EWSdel DA 07 C8 59 FE 0E 2E 0F DB 00
    ca0110C7.DAT
    ca0110CA.DAT
    Original 88 90 88 60 8A 0F 02 10 EA 00
    EWSdel DA 07 9C 5A 1E 0F 4E 0F DB 00
    After editing you have to correct checksums (visit www.ms4x.net for corrector tool) and flash back the file to the ECU.
    Bootmode flashing is NOT required. Thanks doesn't hurt if it helped you.
    Have fun
  2. The Following 52 Users Say Thank You to sda2 For This Useful Post:
    abdulrauf (26th July, 2019), adiagnostyka (15th February, 2022), ali kaptan (1st March, 2022), Andreastech81 (17th July, 2019), antwnhszr (17th July, 2019), autoTkey (10th July, 2020), bearheroes (3rd June, 2020), bimmersk (4th June, 2020), bloomecelec (26th August, 2019), boost turbo (29th October, 2023), Botos Leonardo (24th July, 2019), BRUNOXXX (31st January, 2024), danielif (6th November, 2019), daniersms (24th July, 2019), Digital Under (11th June, 2020), ecufix (21st November, 2023), famozo (26th December, 2019), fenir (17th February, 2020), flaviu_syzu (20th November, 2019), gokart (26th August, 2019), iamfooser (17th June, 2020), iyass (1st February, 2020), KADE007 (6th November, 2019), kismurmi (21st August, 2019), Lambda1 (17th July, 2019), lkjubaking (11th February, 2021), lstuning (9th June, 2020), m3touk85 (14th September, 2020), martinracing (22nd February, 2020), mengu190 (23rd July, 2020), MNenad (6th November, 2019), morgano (24th February, 2020), myma7up (10th October, 2024), pakitko (4th April, 2021), pakman (2nd November, 2020), pioneer427 (17th July, 2019), prusony (7th November, 2019), PsiDOC (17th June, 2020), SALAS (20th June, 2020), Salkhi (4th January, 2023), sefaburak (6th November, 2019), shanny254 (4th December, 2019), sharan25 (18th September, 2024), stoyanov (28th August, 2019), TheNine90 (8th December, 2022), Toutancamon (12th October, 2019), Tronics (13th June, 2020), Volker (30th September, 2019), waldi1979 (20th March, 2021), werner5395 (23rd June, 2020), xoom (26th August, 2019), zar0079 (19th July, 2019)
  3. #2
    May 2017
    Nailed it ;D.
    Oct 2015
    GER
    Thanks! Sharing is caring
    May 2017
    True but for ms43 I will care a bit more .
    At moment had my eyes on MS45
    Oct 2015
    GER
    @Lambda1 MS43 EWS delete is ready as well at least for 430056, 66 & 69. Other versions are also possible
  7. The Following User Says Thank You to sda2 For This Useful Post:
    belge77 (9th August, 2019)
  8. #6
    Nov 2017
    thanks working on ms42 320i 5wk9034 ca0110CA.DAT
  9. #7
    May 2017
    Sure I was one who released 66 or 37 (cant remember) in RR xD. Also got for 55 and 37 ... ... they Iam carring a bit, because all nessecary is released for.
  10. #8
    Sep 2016
    Usa
    e46 323i not work eml light and asc light on
  11. #9
    Shmortz's Avatar
    in the middle of nowhere
    Quote Originally Posted by sda2 View Post
    hello, can you share info for MS43 ver 66, EWS delete?
    Thank you!
  12. #10
    May 2017
    Which Softwareversion you are on?
    After did checksum correction. Also beware on some hardware numbers only some of softwarenumbers works .
    Maybe need AD Version.
    Read DTC and tell em us about.
    Thank you!
    Please read... its everything out there... easy to find. 66 and 69 are nearly identical .
  13. #11
    Mar 2009
    does the flash need to be desoldered or can i read boot pinS
  14. #12
    May 2017
    Can be done via fulllread via k-line or via bootpin.
  15. #13
    Shmortz's Avatar
    Quote Originally Posted by Lambda1 View Post
    I read a lot last night and found version 69, then I patched EWS with tunerpro but it is not fully identical to 66, I don't know what to do because car is far away from here. I know there is people that can do for me EWS delete on my version, but I don't know why they don't want to do this. I allways help people in this forum if I know how...
    I will be verry greatfull if someone shere MS430066 patchlist XDF file.
  16. #14
    Oct 2015
    GER
    I will create a post tomorrow with the code to edit. Send you a PM with patch right now in before.
  17. #15
    Oct 2017
    Can you shear ews delete file for ms43 v37, I have JMgarage ews delete tool but it dose not support V37 or V64 or 69 it sucks for the money you pay for a tool and there is no support from the guy.
