Results 1 to 4 of 4
    McDowell's Avatar
    Feb 2019
    Zamunda
    Default Dacia Logan 2007 Diesel air conditioning not working.
    Hello mates,
    I have an issue with a Delphi DCM1.2 Unit, the air conditioning isnīt working. The pin A-B3 not sending signal to air conditioning unit.
    The past mopnth if seen same issue twice also with a Dacia Duster unit.
    Do you know what could be the problem?
    Thanks very much in advance
  2. The Following User Says Thank You to McDowell For This Useful Post:
    Louislesinge (18th July, 2019)
  3. #2
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    If you have CAN CLIP or maybe with another tool, find command AC028 (Static Test), do it, turn ignition off for one minute and try A/C again.
    Greetings,
  4. The Following 2 Users Say Thank You to Louislesinge For This Useful Post:
    alclot (18th July, 2019), McDowell (18th July, 2019)
  5. #3
    Jun 2017
    French Jungle
    Hi MacDowell,
    Did you test my proposal?
  6. #4
    McDowell's Avatar
    Feb 2019
    Zamunda
    Quote Originally Posted by Louislesinge View Post
    Hi MacDowell,
    Hello mate,
    Iīll let you know as soon as I test it. thank you so much for your answer.
  7. The Following User Says Thank You to McDowell For This Useful Post:
