try and comment.
try and comment.
pocinas (19th July, 2019)
Hi. After connect module again, using diagnostic tool and clear all dtc stored in airbag now all is clear, but still on screen have warning Airbag or seat belt pretensioner fault... the same is on dashboard still.lights 2 light
Any idea?
My post helps you? Please Hit Buttons
HI
YOUR FILE CLEARED
TESTED SOLUTION
PASS IN PM
REPORT BACK
THANKS
IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
This faults been before clean crash data..
After clean crasg data, airbag dont detect any DTC. So is clean but is light on dashboard and info on screen lcd
HI
CHECK THIS FILE
SAME PASS
PASS IN PM
REPORT BACK
THANKS
Hello to all. Test this file.
Thanks a lot all of you.
Tried and tested yesterday.
You 2nd file MOMO works perfect now.
