Results 1 to 5 of 5
    Dec 2017
    france
    Default Help DPF off Renault Koleos 2.0DCI 175 (edc16cp33)
    Hi everybody,
    I need help to do DPF off for Koleos 2.0 DCI 175cv, i have many problem with this car and i must remove the DPF !
    You can find the file extract BDM with galetto .
    Thank you very much for your help !
    Member xam4's Avatar
    Jun 2016
    Earth
    Here is your file. Don't forget to checksum.
  3. The Following User Says Thank You to xam4 For This Useful Post:
    bigbang63 (20th July, 2019)
    Dec 2017
    france
    thank you, how did you do modification?
    Nov 2017
    salut j'ai koleos besoin dpf off s'il vous plaît
  6. #5
    Max001's Avatar
    Sep 2018
    Italy
    Default Dpf Off
    dpf reset with file ori
    disconnect the differential pressure sensor
    disconnect the exhaust gas temperature sensor
