Results 1 to 2 of 2
    McDowell's Avatar
    Feb 2019
    Zamunda
    Default New Beetle 2014 Dash swap
    Hello mates,
    I have a new beetle 2014 year dash completely soaked ;( Do you know is I can swap it with a donor and how?
    I have read 95320 EE (see attachecd) but it also has a NEC mpc which is damaged I donīt think I can read it.
    Thank you so much
    Oct 2014
    Netherlands
    These MM clusters with NEC have an encryption key inside the NEC. If it's deaf then you must either adapt virgin cluster by dealer or extract immo data from engine ECU and make new transponders.
  3. The Following User Says Thank You to H2Deetoo For This Useful Post:
    McDowell (22nd July, 2019)
