Lock the car with key instead the remote
As the title says I almost checked every thing I can thought of all doors locks work, rear boot light switched off, radio and internal lights double checked all in good working order any thing else I need to check customer says all neighbours now started complaining please any one give advice, thanks in advance.
super jumbe (19th July, 2019)
Ok will try that, so does he have to lock car with keys all the time.
yes if he doesn't want to disturb the neighbours
until he repaired the alarm
Had this problem with a Honda Civic lately remote battery was lighting up remote and signal seemed fine put new battery in remote key and cured problem.
Totally different system but maybe worth a try
How do you lock the car with the key, this car will lock automatically seconds before you close the driver door, I did replace new battery to remote, I can only think there could be rats making most of life triggering car alarm…
Post solution if you find one.
Good luck 👍🏻
