Results 1 to 10 of 10
Thread: CD 30 code ?
    ilen's Avatar
    Feb 2013
    Serbia
    Default CD 30 code ?
    Hello,
    Can some confirm , is code ok ?... or is unregister ?
    Blaupunkt cd 30.... eeprom 95640
    Thenxx
    smoggy's Avatar
    Apr 2009
    UK North East
    code is ok
  3. The Following User Says Thank You to smoggy For This Useful Post:
    ilen (20th July, 2019)
    Feb 2010
    WALES
    Quote Originally Posted by ilen View Post
    Hello,
    Thenxx
    Here you go, unregistered, you need display PIN for pairing
    wbr
  5. The Following 3 Users Say Thank You to shooting For This Useful Post:
    ilen (21st July, 2019), LABDANI AHMED (20th July, 2019), Zann (20th July, 2019)
  6. #4
    ilen's Avatar
    Feb 2013
    Serbia
    thanks friends.... now I read display eeprom, if I seen good code is 8427 .. will try...and say the result...
    Thenxx
  7. #5
    Feb 2010
    WALES
    Thenxx
    Pin is correct
    wbr
  8. The Following User Says Thank You to shooting For This Useful Post:
    ilen (24th July, 2019)
  9. #6
    ilen's Avatar
    Feb 2013
    Serbia
    ...I tried to get married with a code displey 8427 ... now write on the display, radio safe.... end beep....?
  10. #7
    Feb 2010
    WALES
    If you used my dump and paired using 8427 then there is a problem with your OBD tool
    wbr
  11. The Following User Says Thank You to shooting For This Useful Post:
  12. #8
    ilen's Avatar
    Feb 2013
    Serbia
    Quote Originally Posted by shooting View Post
    wbr
    ...it's looks ok... I do not know...?
  13. #9
    ilen's Avatar
    Feb 2013
    Serbia
    can any one pair these two damps... without opcom or tech2...?
  14. #10
    ilen's Avatar
    Feb 2013
    Serbia
    wbr
    ...as usual, you were right. Your dump is 100% OK. I finished successfully with Tech2...
    Thenxx
  15. The Following User Says Thank You to ilen For This Useful Post:
    shooting (27th July, 2019)
