as i wrote..............#11
and Louislesinge #15
need help
now my goal is to buy xp-005
who will help?
Louislesinge (21st July, 2019), rikardo1 (21st July, 2019)
now i have to make immoof yes or no?
Here is your off.
Thanks to all the DK team!
Greetings and good night guys,
Pass should be in your P.Ms, isn't it?
Greetings,
Doesn`t work i cut pin 58 ligth of immo turn off but car donīt run
it can be orginal file
i program the flash and solder on ecu cut wire 58 immo ligth turn of but car doesnīt work it can be orginal file
here off.....................pass pm
need help
who will help?
rikardo1 (27th July, 2019)
i donīt know if you can remember but you gave me orginal file because i unsolder on the ecu flash memory m29f200bb i keep and than iīve lost flash memory and i have to buy new memory flash and i canīt not have access to the orginal file is problem canīt not post orginal file and you gave orginal and than lousine gave imoof i program new flash soder on ecu i cut wire 58 but imoo ligth turns off but the car doesnīt work
thankyou
solder and unsolder in this ecu is not good idea...........better to buy equipment - less troubles
need help
who will help?
Louislesinge (27th July, 2019), rikardo1 (27th July, 2019)
k-tag..................
need help
who will help?
