    Feb 2013
    UK Bristol
    Default 4c11-12a650-jg - Delphi. Ford Transit 2.4d 2006 IMMO OFF
    Hi there.
    Would like ask you lads for advice.
    Some have do it IMMO OFF in this Transit
    Can i know is possible do it via eeprom mode/flash mode or should be installed Emulator or is inpossible?
    Thanks for you answers..
    My post helps you? Please Hit Buttons
    avital's Avatar
    I have solution but need mount little PCB board inside ECU, In this method ECU flash and eeprom not need to touch , the board emulate key reader and key 4D DST40 ...
    On foto DELPHI ecu with emulator.
    This work for all ECU FORD with keys 4D inside.
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI / LAMBORGHINI - immobilizer solutions
    Feb 2013
    UK Bristol
    How is the name of this emulator and where i can buy this pcb?
    Need program this emulator? Need reflash flash in ecu?
    Is complicated instructions?
    I am electronic engineer and i got a.lots.of stuff but just like now need some.extra tools over this emulator
    P.s on this photo emulator have 4 wires.. what is the rest wired soldered to pcb ecu?
    avital's Avatar
    Name this emulator - DST40 emulator , about buy... I use this for service task in Poland customer area.
    Need add from key(transponder) the data bytes to emulator , on board exist 24C02 for this storage.
    You don't need instructions , do connect on points the same to connection for the base station (reciver) to communication with keys, RX/TX and power 12V/GND .
    Other wires is for the logic analyzer , it is old foto from 4 years ago when I did developing software to this emulator.
    There is foto this device emu when work with ECU VISTEON from transit 3C11 :
    Feb 2013
    UK Bristol
    Thanks.
    I send you pw
    Feb 2013
    UK Bristol
    No chance for more helps... :-(
