Results 1 to 14 of 14
    EU
    Default Renault Megane 2 EDC16 EGR off
    Greetings to all,
    can somebody help with EGR off on this car, Renault Megane 2 1.9 DCI ,
    HW 8200310863 SW 1037369198 read with Kess.
    Thanks in advance.
    a500tut's Avatar
    Jun 2017
    Belarus
    Quote Originally Posted by ollync View Post
    Greetings to all,
    Thanks in advance.
    Good day for you
  3. The Following User Says Thank You to a500tut For This Useful Post:
    ollync (24th July, 2019)
    EU
    Thanks, i will try . Egr connector must be disconnected?
    EU
    Quote Originally Posted by a500tut View Post
    Good day for you
    Car starts fine, no egr related errors but SERVICE light in dashboard does not go off. No other errors on car.
    Sent from my iPhone using Tapatalk Pro
    a500tut's Avatar
    Jun 2017
    Belarus
    Egr connector disconnected?
    Jul 2019
    Bulgarian , Montana
    Greetings to all,
    Thanks in advance.
    here go disconect plug valve
    pw in pm
  8. The Following User Says Thank You to Rd TUned For This Useful Post:
    ollync (25th July, 2019)
  9. #7
    EU
    Yes, egr connector disconnected .
  10. #8
    EU
    Quote Originally Posted by Rd TUned View Post
    pw in pm
    Thanks, but it is the same file with that from a500tut .
  11. #9
    EU
    Any other solution?
  12. #10
    Jul 2019
    Bulgarian , Montana
    disconect the valve plug and report me have dtc or not , and send the dtc?
  13. #11
    EU
    Valve plug disconnected, no error on engine ecu or other ecus but „ service“ light in dashboard is on . Not the engine management light.
  14. #12
    EU
    Look at foto. I cannot get rid of this service light. Tried battery disconnect, wrote original file back to ecu, i won’t go out.
    Diagnostic with clip shows no errors .
    Any idea?
  15. #13
    EU
    Solved. I pressed the CC switch and Speed Limiter switch and the light got out.
    Edit: both of the files are working
    Thanks all for help
  16. The Following User Says Thank You to ollync For This Useful Post:
    mondis (11th October, 2019)
  17. #14
    a500tut's Avatar
    Jun 2017
    Belarus
    Good job
