Results 1 to 4 of 4
    Jun 2016
    Default Vw passat R36 immo
    What is required to turn off the immo on a r36 passat? Is it also possible to change it from dsg to manual?
    Here is the ecu
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by 00quattro00 View Post
    Here is the ecu
    you can not switch to manual, you need to read eeprom and flash
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
    Apsik's Avatar
    Mar 2015
    just behind you
    ...hmm not with codding...
    Killing DTC gives you nothing. But you can modify the flash to stop the ECU to look for DSG on CAN. The same way you have no more DTC in ABS.
    We have '08 Jetta 3.6FSI running manual box in Accokeek, Maryland
    If you find my post helpful please hit Thanks button.
    You can also hit Reputation button if you are kind enough.
  4. The Following User Says Thank You to Apsik For This Useful Post:
    immoneard (17th August, 2019)
    Jun 2016
    The engine is going into a Toyota mr2 so not worried about any codes it may throw, just needs to run by itself with a manual gearbox behind it
