Did you let cool down the car? And disconnect battery and reconnect and then try OBD?
Obd should work
someone have idea how to read renault clio RS 2.0i 200hp with Sagem S3000 ecu?
I try kess, no read
I try bench pinout with kess, it does id but no read
I try now with fgtech, but doesnt read
Someone idea? If fgtech read is it safe to write?
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Obd should work
AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
FULL SWIFTEC AND EVC RESELLER
FILE SERVICE FROM 8AM - 9PM 7/7
BAPRO 4WD DYNO
Yes, indeed under 50 degree celciius and it will read
thanks!
thread closed
Sedat Garip
Belgium
With Kind Regards,
you just need to disconnected the sensor to allow the read.
i have also tested with liquid motor disconnected and dont work via obd....i made this ecu on the bench
Megane rs sagem 3000 is not a problem to read and write even at 90 degrees in obd. Kess clone.
Kess ori does it without a problem after obd. You can also do Ktag. Then the mass fuul reading the ecu.
