Nobody knows?
Hello friends, I have a question about my private Audi a3 8p 2.0 tfsi AXX, Is it possible that there would be a speed block installed on 210km / h? The second question is is it possible that the lock is on the gas pedal? The pedal goes to a maximum of 90%. The third question is if anyone could chip it?
Nobody knows?
we can try.... upload file
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
Stopro92 (1st August, 2019)
Galletto reads this driver after obd?
Better with kess. What is ecu? Med9.1?
Verstuurd vanaf mijn SM-G960F met Tapatalk
Sedat Garip
Belgium
With Kind Regards,
I do not have a kess, I read from the galletto. Med driver 9.1 * Can ecu 0261S02041 8P0907115. If you can, I would ask for a max safe program.
You need only tuning?
Sedat Garip
Belgium
With Kind Regards,
Yes safe tune, If you could also see with this blockade at 210km / h or if it is established.
(Unless you can make one map with a pop bang, and one without.)
Max speed 250 km/h
Stopro92 (2nd August, 2019)
I tested on the highway and the max was 210km / h
which rpm ?
hmm I do not remember, but around 5900 ~
No one will help?
