Thursday,18,October,2018,22:02:55:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WVGZZZ1TZ9W031591 License Plate:
Mileage: 222700km-138379mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 02 03 08 09 0F 10 15 16 17 18 19 25 37 42 44 46 47 52 55
56 62 72 77
VIN: WVGZZZ1TZ9W031591 Mileage: 222700km-138379miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Cannot be reached 1100
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 MJ HW: 03G 906 021 AB
Component: R4 2,0L EDC G000AG 2115
Revision: --H08--- Serial number: VWX7Z0H63NU182
Coding: 0000078
Shop #: WSC 62723 001 1048576
VCID: 73E247E312A68FA650-8026
1 Fault Found:
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Freeze Frame:
Fault Status: 01110000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 221770 km
Time Indication: 0
Date: 2000.00.00
Time: 07:53:45
Freeze Frame:
RPM: 924 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00001011
Temperature: 13.5°C
Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 051 A HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1804
Revision: 04843012 Serial number: 00000806300214
Coding: 0000020
Shop #: WSC 01324 785 00200
VCID: 112E2D6B087ADDB6C2-8044
No fault code found.
Address 03: ABS Brakes Labels: 1K0-614-517-MK60AT.clb
Part No SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Component: ESP FRONT MK60-AT 0102
Revision: 00H14001
Coding: 0053958
VCID: 68D8208F5B607C7EF5-803C
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 DA HW: 1K0 907 044 DA
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 69DE258B406A4576EA-803C
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 0F: Digital Radio
Cannot be reached
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 56D 919 475 HW: 56D 919 475
Component: PARKHILFE 8K H01 0005
Revision: -------- Serial number: 64211220200207
Coding: 300001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_EPHVA18VW4110000 001006
ROD: EV_EPHVA18VW4110000.rod
VCID: 72EC42E7A5BC86AE5B-8026
1 Fault Found:
12658720 - Databus
U1121 00 [009] - Missing Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 18
Mileage: 216715 km
Date: 2000.00.00
Time: 15:07:44
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 D HW: 1T0 909 605 D
Component: 04 AIRBAG VW8 021 0100
Revision: 02021000 Serial number: 003B9D09VKLV
Coding: 0012340
Shop #: WSC 01324 020 00200
VCID: 3664BEF74154DA8EB7-8062
Subsystem 1 - Serial number: 6332QSME767A3007F
Subsystem 2 - Serial number: 6342QSME7B22276FS
Subsystem 3 - Serial number: 6352QSME7322246DG
Subsystem 4 - Serial number: 6362QSME73222F69O
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 752 0101
Coding: 0012022
VCID: 78F870CF0BC0ECFE65-802C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
4 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1T0 920 874 A HW: 1T0 920 874 A
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: VWX7Z0H63NU182
Coding: 0007103
Shop #: WSC 60595 002 1048576
VCID: 346084FF5728C89E89-8060
Address 18: Aux. Heat
Cannot be reached
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 170708F2000058
Coding: EDA17F06500F028002
VCID: 3566B9FB5C52D196BE-8060
4 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 10
Reset counter: 167
Mileage: 221242 km
Time Indication: 0
Date: 2000.00.00
Time: 23:45:31
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 167
Mileage: 221242 km
Time Indication: 0
Date: 2000.00.00
Time: 23:45:31
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 216697 km
Time Indication: 0
Date: 2000.00.00
Time: 16:26:59
02649 - Digital Radio Tuner
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 216697 km
Time Indication: 0
Date: 2000.00.00
Time: 16:26:59
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 2416
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 3CD 035 682 B
Component: RNS-MID H08 5269
Revision: AB001001 Serial number: VWZ6Z7N7133063
Coding: 04000440000000210000
Shop #: WSC 00081 790 00119
VCID: 377AB3F3865E2386AC-8062
14 Faults Found:
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 222680 km
Time Indication: 0
Date: 2000.00.00
Time: 16:19:45
00821 - Antenna 2 for Radio (R93)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 222680 km
Time Indication: 0
Date: 2000.00.00
Time: 16:20:09
00859 - Line-Output; Front Right
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 222680 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:12
00869 - Line Output; Rear Right
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 222680 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:18
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 127
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:02
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 127
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:03
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 127
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:03
00873 - Bass Speaker Rear Right (R17)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 127
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:03
00874 - Treble Speaker Front Left (R20)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 167
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:07
00876 - Treble Speaker Rear Left (R14)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 167
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:07
00875 - Treble Speaker Front Right (R22)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 167
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:07
00877 - Treble Speaker Rear Right (R16)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 167
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:07
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 127
Mileage: 222684 km
Time Indication: 0
Date: 2000.00.00
Time: 15:56:58
00862 - Antenna for GPS Navigation (R50/R52)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 222684 km
Time Indication: 0
Date: 2000.00.00
Time: 16:19:17
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 N HW: 1T0 959 701 N
Component: Tuer-SG 008 2007
Coding: 0004566
VCID: 428CD2271D9C762E0B-8016
4 Faults Found:
00120 - Outside Warning Light/Door exit Light Driver Side
00131 - Outside Door Handle Illumination/mirror Light Driver Side
01734 - Potentiometer for Mirror Adj. Horizontal; Drivers Side
008 - Implausible Signal
01736 - Potentiometer for Mirror Adj. Vertical; Drivers Side
Address 44: Steering Assist Labels: None
VCID: 55A6197BBC12F1965E-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 9890020851034C7F2D028C0D70084FC6F0FC00
VCID: 030217234206BF2640-8056
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Shop #: WSC 01324
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0316
Revision: -------- Serial number: BP218187337491
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 67DA23B39E7E7306FC-8032
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 M HW: 1T0 959 702 M
Coding: 0000247
1 Fault Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 A HW: 5M0 907 357 A
Component: AFS-Steuergeraet 0001
Revision: H02 Serial number:
Coding: 3293188
VCID: 326C82E7AD3CC6AE9B-8066
Subsystem 1 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0002
Coding: 00000050
Subsystem 2 - Part No: 1K0 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0002
Coding: 00000050
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
14 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 222680 km
Time Indication: 0
Date: 2000.00.00
Time: 16:19:45
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 222680 km
Time Indication: 0
Date: 2000.00.00
Time: 16:20:09
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 222680 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:12
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 222680 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:18
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 127
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:02
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 127
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:03
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 127
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:03
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 127
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:03
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 167
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:07
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 167
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:07
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 167
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:07
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 167
Mileage: 222704 km
Time Indication: 0
Date: 2000.00.00
Time: 23:53:07
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 127
Mileage: 222684 km
Time Indication: 0
Date: 2000.00.00
Time: 15:56:58
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 167
Mileage: 222684 km
Time Indication: 0
Date: 2000.00.00
Time: 16:19:17
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AK HW: 1K0 959 703 AK
Component: Tuer-SG 007 2002
Coding: 0000144
Shop #: WSC 01324 785 1012552
VCID: 79FE75CB30CAF5F61A-802C
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AK HW: 1K0 959 704 AK
Coding: 0000144
VCID: 7AFC6AC735CCFEEE13-802E
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 04:07)--------------------------
Inviato dal mio iPhone utilizzando Tapatalk
