Im running the abgx to verify games ,
I have some writing in yellow which i read is an error and could find help or advice about error.
I have a message dmi is unverified what is and how can I fix this
thx
daz
thx
daz
Can you post image of the window that Abgx throws up when launched
after redoing the other one to get image it seemed to run through perfect but then I have done left 4 dead 2 and got (see image )thx
daz
Once you run it through abgx and gives you the errors it downloads and patches PFI the proper DMI.
Run it through after first time and you will see everthing is as it should be.
This is due to pre-releases etc being released but abgx patches in the proper files. Hence auto fix etc.
Patience is a virtue.
ran the left for dead 2 again
still get in yellow
Pfi does not match known data (could be corrupt data or new wave not seen before)
video partition does not match known data but neither did pfi
stealth status is uncertain
everything else was ok
and at bottom verification was succesful stealth passed.
so does that mean it is ok to play online
thx
daz
I have left for dead 2 as well that does this.
Due to the fact it is wav 5 and abgx has no been updated to read them properly.
Should be fine.
Check verified dmi for etc on the abgx website l4d2 see if they are the same number on abgx when you run it though.
