Results 1 to 8 of 8
    May 2014
    LIthuania
    Default mitsubishi outlander 2.2 di-d 2010y need dpf off
    hi mates i got mitsubishi outlander 2.2 di-d 174cv 2010y ecu denso ra6 inside sh 7058 need dpf off . thanks in advance
    Did you try ads?
    I done one 4007 some time ago and for me working.
    The same car is peugeot 4007 and citroen c-crosser
    May 2014
    LIthuania
    No mate ads solution does not exist cause it is denso . peugeot and citroen do not have denso
    Išsiųsta naudojantis LM-Q610.FG Tapatalk 4 Lt
    pike's Avatar
    Sep 2013
    Your car have limp mode? Send DTCs report.
    May 2014
    LIthuania
    No dtc or limp mode car runs great but oil rising in engine because of regenerations it is common problem in this engines as I found in research
    johak's Avatar
    hi, try this file...
  7. The Following 2 Users Say Thank You to johak For This Useful Post:
    antara06 (15th July, 2022), Davidik (15th February, 2022)
    Feb 2011
    Hello! same car with same problem. Here is my file. Maybe someone can help me?
    Gita's Avatar
    dt.tuning.gita@*****.com
    pass in pm
    CHK OK
