Hi Guys. On the first page this thread i have seen posted Cummins insite Keygen for all versions . However the link is dead now. maybe sombody can share it or repost it..Thanks in advance
To install on Windows XP and Vista For DDDL 6.4 Crack
[code]To install on vista or xp follow these instructions. it is a lot
but you MUST follow these direction exact or it WILL NOT work.
<1>Run the install for DDDL 6.4. program
<2>After install DO NOT run the progran. reboot your computer
<3>After reboot (do not run the program at this time)- Go to
c:\program files\detroit diesel\diagnostics\ and copy
"dddl.exe" and paste it to your desktop (make sure the whole
file copies not just a shortcut)
<4>copy the crack dddl.exe file from the download to
<5>right click c:\program files\detroit diesel\diagnostics\dddl.exe
and run as administrator
<6>enter any 10 numbers. the program will now open. let it open
completely.
<7>close the progran and reboot computer
<8>go to c:\program files\detroit diesel\diagnostics\ and
Delete dddl.exe and put the original file from the desktop in
this directory. (do not copy over the cracked dddl.exe it must
be deleted first)
<9>reboot computer again
<10>Now before you run the program you will need to go back
to c:\program files\detroit diesel\diagnostics\ right click
dddl.exe and go to properties. click on compatibilty tab and
make sure run as administrator is checked. click on ok.
Now you are done installing the program and it should run
with no problems. Then install the 6.44ta upgrade.
