Great downloads man, many thank
Althougt there are some links missing : in part CVC_GET_STARTED there is only one part " CVC_GET_STARTED_.part2" no part 1 and eventually part 3
Please try to upload the missing parts and THANK YOU AGAIN
Is there a keygen needed or password for this
There is a separate program for the new transmissions coming out, any chance of the software?
offcourse here in DK is possible just search botton
and here is the vcads software training guide for all that work with it......just 10 times download
RapidShare: 1-CLICK Web hosting - Easy Filehosting
The program is for a Allison EP 40 and EP 50 Hybrid Electric Transmission. It is for buses. Thanks
HI, great job, need Allison Doc for PC AED, for EP40, EP50 Transmissions. Any help?
Thanks for all the great software. Only 1 problem, the Detroit DDRS keygen has been removed from Rapidshare. Does anyone else have this? Thanks
When I try to install International Master Diagnostics "Install First" I get an error stating Unauthorized user detected. Installation is approved for Ford IDS users only? Does anyone else have this issue? Thanks
It looks like the Master Diagnostics 4-4-3 is requiring a password to install. Is there a keygen available? Thanks
Thanks for the software, I have a trouble with the Master Diagnostic-first installation send a message Unauthorized user detected. This installation is approved for ford IDS User Only. How can fix this trouble. I don?t Speak english. i'm sorry.
you must install the ford IDS, first and then the master diagnostic
tiene usted que instalar el ford IDS,primero y luego el master diagnostic
Gracias. Por el Dato
[quote=ivaCdpr;549839]you must install the ford IDS, first and then the master diagnostic
Gracias. Por el Dato[/quote
English only here, no problem use a translator,
forum rules, so you do not have a problem here
I see that one, but it says 7.5 in the text. Have you done it for 8.0?
