Just wanted to give a shout out to Rs !!!!! You've been a big help since I've joined DK and you deserve alot of recognition for all that you have helped so just wanted to say keep up the great work
Yes he is one of many on here who help everyone
here is your code frank
002-C0F-50B-A1D-60E-000
W=ECM PASSWORD REMOVAL WSS-F59-A15-9EA-D96-3IR Z= OEM, ECM PASSWORD REMOVAL ZSS-358-BE9-FA1-361-3IR F= Fleet CALIBRATION COUNTS AVAILABLE FSS-E2B-55D-378-306-3IR
my friend the keys do not work, thank you very much
Caterpillar Fuel system HEUI - training presentation
http://www.digital-kaos.co.uk/forums...7/#post1032415
I invite...
Frank is the insite program your using insite 7.4 ??? If it is please check your Pc Id number again and give it to me and ill try it again
Frank I need your Pc id Id
99 scooby looks great contribution I have been installing on my computer and flew ddl and throws me errors dandolme can help me to install some reconemdacion q and I could not and I need this program to work and if I peudes collaborate with other software you appreciate the maxx is the service which the logic Diamont dlb builder in advance thank you very much and hope ua hit
i have donload this,
Detroit Diesel ( covers engines MBE-900 MBE-4000 Series 60 and DD15 and DD13 )
DDDL 6.45 7.04
RapidShare: 1-CLICK Web hosting - Easy Filehosting
(crack for DDDL version 6.4)
To install on Windows XP and Vista For DDDL 6.4 Crack
[code]To install on vista or xp follow these instructions. it is a lot
but you MUST follow these direction exact or it WILL NOT work.
<1>Run the install for DDDL 6.4. program
<2>After install DO NOT run the progran. reboot your computer
<3>After reboot (do not run the program at this time)- Go to
c:\program files\detroit diesel\diagnostics\ and copy
"dddl.exe" and paste it to your desktop (make sure the whole
file copies not just a shortcut)
<4>copy the crack dddl.exe file from the download to
<5>right click c:\program files\detroit diesel\diagnostics\dddl.exe
and run as administrator
<6>enter any 10 numbers. the program will now open. let it open
completely.
<7>close the progran and reboot computer
<8>go to c:\program files\detroit diesel\diagnostics\ and
Delete dddl.exe and put the original file from the desktop in
this directory. (do not copy over the cracked dddl.exe it must
be deleted first)
<9>reboot computer again
<10>Now before you run the program you will need to go back
to c:\program files\detroit diesel\diagnostics\ right click
dddl.exe and go to properties. click on compatibilty tab and
make sure run as administrator is checked. click on ok.
Now you are done installing the program and it should run
with no problems. Then install the 6.44ta upgrade.
but i stay onstep 5, can?t run te program, what?s wong?
Does Mercedes truck have transmission software?
A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
Please don't pm me for keys, that is what the forum is for.
If it helped, please use the thanks button, if thanks isn't enough use the scales.
Your first post, you got 3 downloads and you didn't even say thanks for the stuff you downloaded from this thread, classic case of leeching. Follow forum rules and make a post here Introduce Yourself
