Results 1 to 9 of 9
    Aug 2018
    Default DPF OFF 159 1.9 JTD
    Hi, i tray disable EGR and DPF...i have said that you have to remove the connector from the egr but if i do i skip error and the car does not work well. watching logs and the egr is disconected.
    I dont know if the DPF is turned off completely. Any help?
    Sorry for my english.
    HW 0281013576
    SW 1037391754
    I have said that you have to remove the connector from the egr but if I do I skip error and the car does not work well. Watching logs the EGR is disconnected.
    Nov 2017
    ITALY
    This is the file with egr and dpf off ok. The file you read is not original,
    they made a bad map. Good job. P.S: Pass in private.
  3. The Following User Says Thank You to EGS For This Useful Post:
    Darkitu (7th August, 2019)
    Aug 2018
    So...the original map is remaping?? I thought the car it was stock ecu. How Bad is it?
    Aug 2018
    Someone else?
  6. #5
    HIC's Avatar
    Apr 2010
    Quote Originally Posted by Darkitu View Post
    Someone else?
    Did you try file send by SGS .
    What is your problem ?
  7. #6
    Nov 2017
    ITALY
    Yes the file is not original. I modified the file you gave me, so I reported the changes that were there. It is nothing of a light map.
  8. The Following User Says Thank You to EGS For This Useful Post:
  9. #7
    Aug 2018
    Quote Originally Posted by HIC View Post
    I use winols and ecusafe to turn off EGR and DPF but the EGR DTC appeared with the EGR connector removed. I don't know if everything was well done.EGS looked at the original file and saw that it was modified.
    I bought the second hand car and I would like to know what they did to him in ecu.I have made 300km with my DFP file off and EGR off and at the moment I don't have any type of fault.I am looking to learn and if it is not very difficult I prefer to be told the mistakes.
  10. #8
    Nov 2017
    ITALY
    I didn't understand, do you have any problems with my file ?? I can guarantee that the file is worked well for dpf egr off. 100%.
  11. The Following User Says Thank You to EGS For This Useful Post:
  12. #9
    Aug 2018
    I have not been able to prove your file, nor have I asked for the code by mp ... these days I did not have the necessary cable.
    What I would like to know is that they had modified in the ecu to not be the original file, as I say, the car is just bought and I thought it was without any modification in the ecu. I'm sorry for my English.
