Results 1 to 11 of 11
Thread: R4i SDHC Error
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Default R4i SDHC Error
    HI guys
    Got meself an R4i card thats being a pain. I have tried all firmwares avail, the card loads up but when i launch a game, its saying savfile not found please reset system.
    Tried the arm 7 fix, again no games load at all. any advice would be very good as the dsi is about to go outta the window .
    The card is for 1.4 (got the big star on box) This is the only R4 card i have had trouble with. So tried 1.14 1.13 1.12 versions none work. Arm 7 fix tried and failed.
    Cheers
    DK Veteran billy2's Avatar
    Jul 2008
    some where over there
    is it all games m8 or just the one ??
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
    sometimes life will kick you around , but sooner or later , you realize you`re a warrior , and your stronger than anything life throws your way !!!!!!!!!!!!!!!!!!!!!!
    cunny's Avatar
    Jan 2009
    The Shoutbox
    all games tried arm 7 fix on them still no luck
    Jul 2008
    did you have a look here m8 R4i-SDHC Kernel Download also have a look at the box and see if there is a web site printed on it
    cunny's Avatar
    Jan 2009
    The Shoutbox
    done all think the card is faulty, i bought 8 at once and all others work, only thing is this is my lads that dont bloody work
    hi cunny
    did u try and format the card using panasonic sd formatter. Its free just google it cause i had the same problem and it worked for me hope this helps
    Also i have a slight problem is the loading speed for my r4i is very slow. It takes like 3 to 4 minutes to load a game have you ever heard of this and is there a fix thanks
    Dec 2010
    Default have same problem
    just bought this card, after having used r4igold no problem - guess I should have stuck with that. Anyway I will keep looking for a solution.
    ..and let you know
    V.I.P. Member barrowmanandrew's Avatar
    scotland
    Quote Originally Posted by cunny View Post
    HI guys
    Cheers
    hi m8,
    do you have a link to the site where u bought card?
    which ds are u using?
    V.I.P. Member mickydibble's Avatar
    Nov 2008
    modsvilla
    Can u try the memory card in the other cartridges? or I expect you don't have them now/as your son updated is dsi check firmware also try the 1.20 b I uploaded .... Micky
    Default r4i
    Help please my 2 grandsons got dsi from santa and one of the buggers went on line and updated his.
    No r4 cards work now.
    Any tips please on what i can do ?
    Mike
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Will have to buy a new card thats 1.41 compatable
    Bloody hell just noticed this an old thread. I remember now getting the card changed and was bought at a car boot. The card was faulty
