Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    Aug 2009
    Slovakia
    Default IBIZA 2002 1,9 TDI PD
    Hi i?m lookink for wiring diag. of power distribution of this car. I have problem that fuse (18)from instrument cluster blow in few seconds also fuse for reversing lights (19). And without power in cluster car will not start because immo module is off.
    Meat-Head's Avatar
    start with unplug the reverse light switch.
    check the vechile horn, just incase these items have gone down to earf.
    Aug 2009
    Slovakia
    Fuse from reversing lights was blowed for a long time. And today my friend have replaced it. And this was start of problems. I will check light switch and horn tomorrow and I?ll write report.
    Aug 2009
    Slovakia
    Disconnected dash,clima, reversing light switch, horn.... still 19A on fuse no.18.
    Wiring diagram show what else is on this fuse. Any help?
    Meat-Head's Avatar
    Quote Originally Posted by erikfrog View Post
    un-plug ciggerette lighter
    check around the gas pedal no wires have chaffed.
    do the front and rear wipers still work?
    do a full test of lights etc and see what doesn't work.
    Aug 2009
    Slovakia
    still nothing everything works. But I have checked next fuse 19 (reversing lights) after disconnecting rev. lamp and switch fuse blown...
    So there must be something that have these two fuses together. Both wires go somewehere in the middle or right side of the dash.
    As i have written problems came after replacing rev lights fuse. And I think that this wire has damaged (melted)isolation somewhere...
    Meat-Head's Avatar
    if you put a 55 watt bulb instead of a fuse, as you find the fault the light will go out saving you a fortune in fuses.
    look at the ends of the wires, where the oxygen is, if encased wires do not normally burn due to no air.
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    If the problem is performed when replacing the switch reverse lights, there should be and start and stop lamps to see if there some problems.Check installation problem in mind that the accident was not burnt part and stick the two cables, not the vehicle and hit someone accidentally screw in doorstep and into installation ... I hope that you will draw something from this.
    Ashraf6119's Avatar
    Nov 2009
    UK
    Fuse F18 is 10amp is for A/C, Heater Recirculation, Electric heated Door Mirrors,Head lamp Adjustment, Instrument panel, and Navigation System.
    Fuse F19 10amp is for Heated Windsceern, Washer Jet, and Reversing lamp.
    So worth checking all those system connected to this two fuses.
    Also check the bulbs if they are right one fitted.
    Hope This Helps
    Ash
    Jul 2009
    Busswil Switzerland
    tray to disconnect the wiring for rear boot. and replace the fuse
  11. #11
    Aug 2009
    Slovakia
    Quote Originally Posted by Babanovski View Post
    Is somewhere plug?
  12. #12
    Aug 2009
    Slovakia
    Quote Originally Posted by Ashraf6119 View Post
    Hope This Helps
    Ash
    Disconnected Dash, Climatronik, Headlamp adjustment, reversing lights, Mirrors.
    Continue today.
  13. #13
    Ashraf6119's Avatar
    Nov 2009
    UK
    Have you checked the wirings back of the fuse box ?
    Ash
  14. #14
    Meat-Head's Avatar
    Continue today.
    unplug the washer jets and make sure it has chaffed on the bonnet hinge.
    or for 10 seconds keep the fuse linked out and stop the instant you see smoke (bad idea, but needs must!)
  15. #15
    Aug 2009
    Slovakia
    Ash
    Yes completely revised wirings under dash....
