Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Jul 2008
    Your browser is just where you would enter details to search for a web page etc. Its a search function at the top of the page. If you go to windows explorer (using the method I have posted) you will see "My Computer" in your windows explorer browser - top right of page.
  2. #17
    Sep 2008
    soz its coming back as ftp error make sure you have permission to put onb server is that because i am doing on browser
  3. #18
    Jul 2008
    I am not sure why you are getting that message unless you are tying the wrong dreambox ip.address into the browser.
  4. #19
    Sep 2008
    yes its coming back as an ftp folder error
  5. #20
    Jul 2008
    sorry mate not sure what that is.
  6. #21
    Sep 2008
    thats what on dreambox in set up . does it make a difference if goes through wireless router
    <--gingerninja added 10 Minutes and 14 Seconds later...-->
    duno think clutching at straws it seems not working dunno what to do
    <--gingerninja added 653 Minutes and 41 Seconds later...-->
    i had problems downloading the ipswitch file. isnt anything straight forward. its giving a warning that it has errors
    <--gingerninja added 7 Minutes and 37 Seconds later...-->
    hi there thanks for your asistance last night but still cannot transfer files
    there is obviously something not write. i have followed everyones instructions but stil cannot transfer files
    is it possible to transfer from dream up or some other way.
    Last edited by gingerninja; 17th September, 2008 at 10:06 AM. Reason: Automerged Doublepost
  7. #22
    Administrator
    Devilfish's Avatar
    Feb 2008
    No dreamup is only for images.
    Try changing the ethernet cable or verify your setup with another dreambox.
    Or do a factory reset on the box you have and try again.
  8. #23
    Sep 2008
    Default still cannot transfer files from pc to dreambo
    i have dreambox connected to router and modem
    there is a connection byt files will not transfer via flash or copying and paste.
    the message on flash says in green 200 ASCII tastes bad dude
    one file failed to transfer
    when i cut and paste susing bugaloo instruction
    200 binary it is then
    227 enter passive mode
    555 could ot creat file
    can anyone solve problem
  9. #24
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    What you using to ftp the files?
    I dont like flash xp personally i find dreambox control centre does the business a lot more efficiently.
    Patience is a virtue.
  10. #25
    Sep 2008
    where can i get this please
  11. #26
    Apr 2008
    look in downloads section
  12. #27
    Sep 2008
    hi there right i downloaded dreambox control and it looked like the files were transferring from pc to box. done a test and everything is connected box flashes updates software.
    initially it did not and i asked to recieve files from box and then it started to work.
    however rebooted box and switched and restart, reboot enigma and still nothing still got free to air channels no premium still locked.
    any thoughts
    surely it should not be this difficult.
  13. #28
    Apr 2008
    Do you have DM500c? Did u ftp all rom file to var/keys? if not, delete all the file in var/keys first and then ftp nagrarom7, nagrarom10 and nagrarom11 to var/keys forlder in the box. reboot the box and it should be fine. If not let me know.
  14. #29
    Mar 2009
    i use to had the same problem but it sorted without changing any thing ..
    i dont know how ..
