Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    Jul 2014
    Quote Originally Posted by a500tut View Post
    Yes, it's the best variant, remember that you do this at your own risk, you will lose the BMW warranty
    i write this file by ktag
    car is started
    after i write dpf+egroff file by kess,car is not start
    and i try with orig file the same not start((
  2. #17
    a500tut's Avatar
    Jun 2017
    Belarus
    BMW Tprot is working
    If I helped you, click thanks and reputation
  3. #18
    May 2017
    Use brain and you will found your faux pas-
  4. #19
    Jul 2014
    Quote Originally Posted by Lambda1 View Post
    you have the solution??
  5. #20
    a500tut's Avatar
    Jun 2017
    Belarus
    Ok, try this version via ktag! pass same
  6. The Following User Says Thank You to a500tut For This Useful Post:
    filxomor (20th August, 2019)
  7. #21
    Jul 2014
    bro, location Tprot is in maps???
    ktag when write it write the maps
  8. #22
    a500tut's Avatar
    Jun 2017
    Belarus
    Maps is full flash 1.5mb, tprot in full flash, if car start, it's be a good result!
  9. #23
    Jul 2014
    Maps is full flash 2mb, tprot in full flash, if car start, it's be a good result!
    the same
    with this file when i write it by ktag car is start
    but then, when i write mod file by kess it is not start, even if i write orig file
  10. #24
    a500tut's Avatar
    Jun 2017
    Belarus
    Ok, you dont write file by kess, you need write file by ktag!
    But need do dpf +egr+stage1 on full flash file for ktag...
  11. #25
    Jul 2014
    yes, for the first time i write it by ktag
    after i write mod file by kess on obd
  12. #26
    a500tut's Avatar
    Jun 2017
    Belarus
    Try this file for ktag, pass same.
  13. The Following User Says Thank You to a500tut For This Useful Post:
  14. #27
    Jul 2014
    i write this
    it is ok
    not errors
    tomorrow i wiil test it on road
    thank you mate
    in this ecu is not possible tprot off???
