can im608 reset fem mileage ?
You cant reset mileage with IM608.
Sent from my SM-G986B using Tapatalk
Can we precode transponders with just XP200 if using another device to read eeprom data or only XP400?
Edit: Apparently xp200 can do precoding if you use another dives to read like vvdi2. Ended up buying xp400 and gbox2 anyway.
mikajna (28th November, 2021)
Yes you can, put dump on usb memory, and put usb memory direct in im508 usb port...then tranfer dump to autel local memory.
But xp200 has huge limitations...he can prepare only some transponders, id46, id48 maybe few mores transponder id's.
Tiris dont work, I've try few of thems 4d60, 4d62, 4d63...cant unlock tiris toyota
Послато са SM-A725F помоћу Тапатока
On the IM model.
At least for the 600/608.
There is a hidden MiniSD slot.
Under the battery cover. (quite happy, when I found this one).
So easy to transfer files, between a computer.
Best with USB- MicroSD adapter.
Then good to read dump, with IM programmer.
And maybe do some work with the VVDI2.
But not so easy to navigate the file system on the IM pad. I wish it was better.
But is possible to search name, to find the files.
key4man (28th November, 2021)
I was found on local im508 memory user folders where are placed dumps, and make that folfer as favorite...than when open usb stick memory on im508 make copy dump, and when need to navigate I use favorite location, and copy/move dump from usb stick memory, in folder where autel will store when read it. For example, in FIAT folder place fiat bcm dump.
When autel open file manger to navigate me to choose dump, dump is there like that autel read it.
Weasel3 (28th November, 2021)
no need to play with sd nor usb stick. You can connect your PC and your 508 the the mini usb cable (marked OTG) it should be appearing under "This PC" --> "Devices and drivers" --> "IM508"
looks like in the picture but not ASUS obviously
edit:
and the path is:
im508 --> Nand flash --> Scan --> UserData -->
New update for Toyota.
OtoSys IM600 IMMO_Toyota V3.72 2021-11-24
Toyota:
Adds Add Smart Key, Erase Smart Key, PEPS Reset, Back up IMMO Data and Generate Analog Key functions for 4A smart key-equipped models of 2021 below: Corolla (fuel/HV), Corolla Touring (fuel/HV), Corolla Sport (fuel/HV), Corolla Cross (fuel/HV) and Levin (fuel/HV). [First released password-free functions]
mikajna (28th November, 2021), whiskeyman (29th November, 2021)
Fiat Ducato 2020 -no success. Can not read eeprom. Possibly a model with sgw?
Read server is/was down for 3 days. amazing guess we stop work
Solidarity with Ukraine
2020 is a cross over year between last of the old and first of the new systems , the ducato doesnt have SGW , it is though a new system that no one has cracked and released yet , but definitely does not have sgw.
ive had 2020 and 2021 registered ducato motorhomes code in without issue , ive also had 2020 models of ducato on new system that have failed , this isnt surprising as many motorhomes are earlier built models before being built into motorhomes.
until the new system is cracked , no aftermarket tools will work for keys
Alpaholic (3rd December, 2021)
Did somebody made a Smart 453 year 2019 with Keydiy ZB Smart Key 3-button remote?
I just cannot make my mind up buying this tool if Golf 7 with VDO cluster can't read immo data with IM608 the tool is useless.....
