Page 55 of 62 FirstFirst ... 5455051525354555657585960 ... LastLast
Results 811 to 825 of 921
  1. #811
    Dec 2021
    Hello.
    Subaru Outback 2021 USA AKL can't do it. This car have another procedure to lean a key. Haven't menu Reset smart box. ((
    I need reset Smart Key ECU (SMT Main ECU 88801AN000) + Steering Lock ECU. Have any body idea how can do it, not for free)
    May be some other device may reset this unit? If not possible, I may read MCU and eprom from it, and get dump for clear.
  2. #812
    Mar 2015
    I have done 3 push to start 21 outbacks here in US with 608. Yes you need internet and you will need to reset system 16mn.
  3. #813
    Dec 2021
    I haven't button reset smart box in menu for outback 20+
  4. #814
    Mar 2015
    I hope you don't mean smart box programmer
  5. #815
    Toyota corolla 2021 Europe 4a smart key fails to ad key by g box connecting to the Smart Key ECU
  6. #816
    Mar 2018
    UK
    Quote Originally Posted by key4man View Post
    You can't read the smart box or can't add the key?
  7. #817
    Default toyota corolla 2021
    I could not read using the autel cable, the sockets in the smart ecu are very delicate, and a small mistake in inserting the penis can do irreversible damage
    I bought a new cable today with good connections, which will replace the autel cable
  8. The Following User Says Thank You to key4man For This Useful Post:
    Manta1600 (1st March, 2022)
  9. #818
    Mar 2015
    Lol yeah if you stick that thing in wrong she might smack you . sorry had too!
  10. The Following User Says Thank You to KEYTH For This Useful Post:
    arosta (25th February, 2022)
  11. #819
    Newbie golnikov's Avatar
    Feb 2022
    Moscow, Russia
    Quote Originally Posted by Matronix View Post
    It's add key, but if it is for sure Autel cannot do it, the KS518 fails on it and Abrites/Avdi (official license) fails on it, i will pass since I don't have the TMPro license for this activated (my TMPro2 is sitting in a box and the software is not even installed). The keys I can get are OEM but customer comes from far... not a good idea to start experimenting too much while he is in the 'waiting room'
    This is just what makes it a risk to do - Autel says it supports it and checking the function it looks like it's all there (reading immo data, making dealer key, programming it, etc). Would love to give it a try just for the sake of it but not on a car from a customer far off who wishes for 2 new keys and will be whining when it cannot be done, better to leave it alone then. Maybe sometimes if it's one closer to home or if I spot one at one of my cartrader customers.
    Perhaps it is no longer relevant, I just saw the topic, but I did alfa romeo brera on such a key. Filmed TEG and wrote on dump 24С04 tango, only opened via fiat. After that, I turned on the ignition, then I started the key registration procedure using Multiecuscan, a pin code is not needed for this. The car started and the remote worked. The key was used, they made it new before I wrote it down my colleagues, with which tool I did not ask.
  12. The Following User Says Thank You to golnikov For This Useful Post:
  13. #820
    Mar 2018
    UK
    So finaly did you read the smart box?
    Can you share the link for the cable
  14. #821
    Quote Originally Posted by Manta1600 View Post
    The cable works very well ,adding another key succeeded
  15. The Following User Says Thank You to key4man For This Useful Post:
  16. #822
    Feb 2022
    Sweden
    @key4man
    Maybe he missed the ?
  17. #823
    Quote Originally Posted by Keyim View Post
    @key4man
    https://www.keyshop.co.il/
  18. The Following 2 Users Say Thank You to key4man For This Useful Post:
    Manta1600 (2nd March, 2022), milehighlockdoc (20th April, 2022)
  19. #824
    Mar 2015
    15 VW Touareg add a key. everything goes fine. Key in slot will start the car, remote works fine except push to start is not working. Think it's the key? Thanks
  20. #825
    Mar 2015
    twas the key.
