Page 26 of 62 FirstFirst ... 16212223242526272829303136 ... LastLast
Results 376 to 390 of 921
  1. #376
    foxtec800's Avatar
    Jan 2010
    Quote Originally Posted by Jimmy07 View Post
    Would dealer not see there was a key programmed to position 1 and program it back in if spare key or just use position 1 if AKL ?
    when you program keys with odis it only shows you the number of keys programmed before erasing and programming all keys. if cs is the same and not changed it should
    reprogram a key added with another tool so dont see why it shouldn`t accept the key back in ?
    i have programmed keys i have created with avdi/vvdi to the car with odis afterwards in certain conditions without issue
    but i dont have im608 so im not certain it will do those, but cant see why it wouldnt
  2. #377
    ghostrider72's Avatar
    Jul 2012
    UK
    When you buy those files from anywhere... Key ID is different from what GeKo online have in their system.
    So once you code that keys it will work fine but if car will go to the main dealer for any online coding which involves immo adaptations, that keys will be erased and there is no way you will add it back to the car with ODIS. Simple because key ID is different.
    Those generators just calculates random (car specific off course) immo data
  3. #378
    foxtec800's Avatar
    Jan 2010
    i`ve never used akl solutions other than ordering from dealer Ghostrider .
    We`re not mobile so when they do happen they come to use and wairt for dealer key when needed.
    it takes longer but we dont have any of the future problems some have by changing immo data
  4. #379
    Jul 2019
    I had a problem with my autel im608. Not able to program akl even in advance mode for 2011 vw Jetta and 2013 vw Jetta this past week. Both are push to start. Anyone else have problems with these. Regular ignition always works, but never had any success with the kessy.
    Sent from my LYA-L09 using Tapatalk
  5. #380
    tepSIJA's Avatar
    Dec 2015
    OTP
    Quote Originally Posted by madsci69 View Post
    on which part of the programming exactly you have a problem ?
    Tempus Omnia Revelat
  6. #381
    Jul 2019
    Quote Originally Posted by tepSIJA View Post
    In an all keys lost situation it will not retrieve the immo data/enter service mode. This only happens when attempting a vehicle with kessy. And it happens with both advance mode through obd and when removing the dashboard to directly edit the Eeprom into service mode.
  7. #382
    Oct 2018
    Northern Ireland
    Can 608 open boot through OBD on F series BMW ?
  8. #383
    fred77's Avatar
    Jun 2019
    i asked an Volkswagen technician if he's ever had an issue with aftermarket keys...
    Looked at me strangely and said he hadn't a clue what i was on about.
    Tho best still to clone working chip rather than write new one as AKL.
    WTF can we do anyway more than that we have a right to make money as much as tho Germans cheating with emissions s
    Solidarity with Ukraine
  9. #384
    fred77's Avatar
    Jun 2019
    Funny today the dealer with this cheaper version tool asked me to program a 2017 vauxhall viravo fob
    ...obviously bug still exists
    Anyway Iveco 2010-2014 system ... no comms
    (SmartPro pre-coded but no comms, Abrites did the job )
  10. #385
    Dec 2010
    Nottingham
    avdi is good on iveco , what tool does the dealer have
  11. #386
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by rapidlocksmiths View Post
    shitter version of the im608 mentioned here
    tool is too cheap - guess join the queue of em
    Abrites has its strong points.
    What pisses me off if i damage a vehicle it costs me £££ but these guys expect me to code key for nothing.
    Big risk for little money
    Oh still should be happy many are outta job now sadly in this virus climate
  12. The Following User Says Thank You to fred77 For This Useful Post:
    Weasel3 (25th September, 2020)
  13. #387
    Dec 2010
    Nottingham
    i know that one , they all want it cheap , but if dealer is doing his own with his cheap tool then he pays double for the job his tool cant do .
  14. #388
    Oct 2018
    Northern Ireland
    Took your advice on this one Rapid. Had a dealer stopped using me then called looking a 2018 Ford Galaxy spare done as beer brigade couldn’t do it
    I charged like a wounded buffalo
  15. #389
    Jan 2010
    Iveco daily 2009 lonsdor failed to connect obdstar x300 read eeprom after a few times then failed to connect when try to program the key.
    MVP pro programmed the remote in fine, didn't want to use a token on the key so tried im608 and it sailed through.
  16. #390
    tepSIJA's Avatar
    Dec 2015
    OTP
    few days ago i finish Skoda Kodiaq MQB 2017 with Autel IM508 and xp400
    15 min , in and out
  17. The Following 3 Users Say Thank You to tepSIJA For This Useful Post:
    fred77 (10th October, 2020), lion0304 (5th October, 2020), p1et (5th October, 2020)
