friend with what did you read ?? fg tech ???
the problem should be the loss of the injector codes .....
Hello everyone, need big favor if someone can please help with very big problem,
wrote a file using kess and after file was completed the car wouldn't start anymore.
ECU id is 0281013855
23710 JD78B
I suspect the eeprom is corrupt, I attached bdm read if someone can make a miracle,
DTC's are
P0611 (inj. codes)
P1612
thank you!
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
Hello, with kess, I did read injectors and saved them but won't let me write the file back either and neither using Launch diagnostic tool.
Try with gallo and renault protocol,search fuction code reader inj and read
