Results 1 to 5 of 5
    Sep 2016
    Default Honda CR-V 2007 DPF Off but engine check light On help!
    Hi friends, need correct Dpf Off this Honda CR-V, car has made Dpf off somewhere,tried another solution but cruise control not works, no errors on ecu but check light is ON, can someone take a look at this file to see what is wrong?I post both files,dont have ori file:
    1. file cruise Ok but check light on
    2.file check light off but cruise control Not ok
    Thanks in advance.
    SW version is: 1037393648
    Honda Cr-V 2007 EDC16 2.2 cdti
    Try this DPF/EGR OFF.
  3. The Following User Says Thank You to x-treme For This Useful Post:
    quato79 (13th August, 2019)
    Sep 2016
    Thank you very much , will try and report back!
    Aug 2018
    Portugal
    I can do it, tested on atleast 4 Crv's ive made in the past, pm me back if u want
    Quote Originally Posted by quato79 View Post
    Did it work?
