please help you on dpf in ecu edc16u34 from engine bxe to engine bls ecu. ecu nummer 03g906021tb
read id with kess and post info
edc16u34.rar send rar
In your file DPF ON, what do you want?????
looks to me dpf off and egr on!!!
please dpf onn. no off. ecu in engine bxe no dpf to swap ecu to engine bls, bls engine dpf its 100 percente good flash no dpf to on dpf in flash
Oh my god = oh gospode
TPS (14th August, 2019)
kamil1234 (14th August, 2019)
help please car dont start swaping ecu fault p1640 internal fault softwaru.... help software from bls? or destroy it ecu writing flash bls software?
Hmm, this guy seems to be the only other guy in the world that speaks Meathead.
original ecu is dead ecu has been replaced and new ecu has turned off immo ecu numbers are not the same car now does not start error p1640 is possible when uploading soft from original ecu not the same but soft downloaded to here original ecu to ecu which is in the car or it helps solve the problem or destroy the ecu
You try swaping software between ECU from BXE and BLS? This ecus have diferent software numbers. Why? I think you corupt ecu...
