Results 1 to 14 of 14
Thread: dpf on
    Jun 2019
    slovakia
    Default dpf on
    please help you on dpf in ecu edc16u34 from engine bxe to engine bls ecu. ecu nummer 03g906021tb
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    read id with kess and post info
    Jun 2019
    slovakia
    edc16u34.rar send rar
    Nov 2009
    Poland
    In your file DPF ON, what do you want?????
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    looks to me dpf off and egr on!!!
    Jun 2019
    slovakia
    please dpf onn. no off. ecu in engine bxe no dpf to swap ecu to engine bls, bls engine dpf its 100 percente good flash no dpf to on dpf in flash
    carbon7319's Avatar
    Aug 2011
    Macedonia
    Oh my god = oh gospode
  8. The Following User Says Thank You to carbon7319 For This Useful Post:
    TPS (14th August, 2019)
  9. #8
    Nov 2015
    Lublin/poland
    Quote Originally Posted by kamil1234 View Post
    dpf on
    for free
  10. The Following User Says Thank You to kostrz3 For This Useful Post:
    kamil1234 (14th August, 2019)
  11. #9
    Jun 2019
    slovakia
    help please car dont start swaping ecu fault p1640 internal fault softwaru.... help software from bls? or destroy it ecu writing flash bls software?
  12. #10
    Jul 2019
    Everywhere
    Hi, You can explain in English what happened to you and above all what you need. within the limits of the possible blind to help you.
  13. #11
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Hmm, this guy seems to be the only other guy in the world that speaks Meathead.
  14. #12
    Jun 2019
    slovakia
    original ecu is dead ecu has been replaced and new ecu has turned off immo ecu numbers are not the same car now does not start error p1640 is possible when uploading soft from original ecu not the same but soft downloaded to here original ecu to ecu which is in the car or it helps solve the problem or destroy the ecu
  15. #13
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Why don't you swap with ECU with matching numbers
    Sent from my Redmi 5 Plus using Tapatalk
  16. #14
    Junkyard Dog's Avatar
    Mar 2019
    EUROPE
    You try swaping software between ECU from BXE and BLS? This ecus have diferent software numbers. Why? I think you corupt ecu...
