Results 1 to 5 of 5
    Jun 2016
    Default EEPROM file need
    Hi guys
    Can any one help me out with an original ecu files - fiesta 1.4 please
    3S61-12A650-LA5WS40069A- T SID 804
    https://ibb.co/QnS3tV3
    Or could someone please confirm if this file from the ecu is box standard as it causes the car to smoke (unburnt fuel)
    https://gofile.io/?c=uUd0dQ
    thanks in advance
    Jan 2018
    PL
    here,,,,,,,,,,,,,,
  3. The Following User Says Thank You to rch11 For This Useful Post:
    GabyGadget19 (14th August, 2019)
    Jun 2016
    Thank you so much,
    Ill try it during next week at the latest and ill get back to you and if it works ill paypal you for your help.
    Jun 2016
    rch11, thanks for your help. Loaded it up onto my m8s ecu and it started. Still smoked but not as bad, lacking power and the speedo stopped working. Got another ecu coming with matching numbers and will see what happens.
    Jun 2019
    vous avez une fista essance ces pas deiesl
