Results 1 to 4 of 4
    Feb 2011
    North of Bronx
    Default 10 Acura TL - need help
    Hello DK -
    I tried with no success a few clears (including CarProg one) and still get 51-20 Internal failure of SRS unit DTC. If I clear, light goes off, and in 3-4 seconds comes back.... same code. Passenger seat is good, everything else is ok.
    Anyone has a confirmed clear for this model? Or some ideas on what may cause the 51-20 DTC?
    I attach dump.
    Thanks in advance,
    A
    Bens's Avatar
    Oct 2016
    Indonesia
    if i help don't forget THANKS AND REPUTATION button
  3. The Following User Says Thank You to Bens For This Useful Post:
    angelo44 (16th August, 2019)
    dmka's Avatar
    Oct 2013
    Vatican City
    Here you go....
  5. The Following User Says Thank You to dmka For This Useful Post:
  6. #4
    Feb 2011
    North of Bronx
    Bens - with your clear i have same code: 51-20.
    I will try DMKA's version next.... will post results....
