Results 1 to 7 of 7
    Jun 2015
    Default peugeot I need help
    peugeot and citroen
    I need an expert friend
    problem
    peugeot 206 1.4 petrol year 2004
    indicators go and come back again
    wipers sometimes work
    samux's Avatar
    Oct 2017
    check your bsi, water damage or going to die
    If I helped, dont forget use buttons reputation+thanks
    Dec 2016
    hi friend check bsi or bsm regatds.
    Aug 2019
    often water gets into the bsi module
    Aug 2019
    sometimes you can do bsi reset and it works. only google bsi reset and you get some intructions!
    hope it works
    PierreTheron's Avatar
    Centurion,South Africa
    Check for sligt waterdamage on bsi .
    If not replace with same exact part no,,,,
    You can also try replace the eepom m8
    It might work ...
    Sep 2010
    europe
    Hello !
    Change the COM switch. ( lights and wipers switch).
    Best regards Tom
