Contact me friends im. Pm I will help you ^^
Hi guys may I please get help with the coding for this vehicle:
Wednesday,14,August,2019,17:52:08:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
Dealer/Shop Name: Team Tronics Auto
Workshop Code: 981 73360 089128
VIN: WVWZZZ1KZ9P446789 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9P446789 Mileage: 185590km-115320miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CAX) Labels: 03C-906-016-CAX.clb
Part No SW: 03C 997 016 HW: 03C 906 016
Component: MED17.5.5 7589
Revision: L3H04--- Serial number:
Coding: 0000077
Shop #: WSC 55307 981 65221
VCID: 66C3DCFE51A6E7723A-8032
4 Faults Found:
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 36.0°C
Absolute Pres.: 900.0 mbar
Voltage: 12.065 V
000567 - Manifold Pressure / Boost Sensor (G31)
P0237 - 000 - Signal too Low - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 36.0°C
Voltage: 12.065 V
006418 - Pressure Sensor for Brake Boost (G294)
P1912 - 000 - Short to Plus
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 36.0°C
Voltage: 11.938 V
005161 - Circuit for Brake Vacuum Pump
P1429 - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 259 /min
Load: 47.0 %
Speed: 0.0 km/h
Temperature: 59.0°C
Temperature: 36.0°C
Voltage: 11.049 V
Readiness: 0010 0001
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 048 L HW: 0AM 927 769 D
Component: GSG DSG AG7 431 9034
Revision: 00043014 Serial number: CU501304286067
Coding: 0000020
Shop #: WSC 45088 000 1048576
VCID: 397947827098B88AA7-806C
2 Faults Found:
006247 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Reset counter: 10
Mileage: 185576 km
Time Indication: 0
Date: 2014.01.03
Time: 22:26:42
006011 - Clutch 1
P177B - 007 - Tolerance Limit Reached - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 2
Reset counter: 10
Mileage: 185577 km
Time Indication: 0
Date: 2014.01.03
Time: 22:52:19
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 00028 028 00001
VCID: 75E18BB2DC001CEA83-8020
3 Faults Found:
03306 - Coding Not Valid
000 - - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 177
Mileage: 185594 km
Time Indication: 0
Date: 2014.01.04
Time: 00:43:49
Freeze Frame:
Count: 3
Count: 14
Count: 12288
Count: 4161
Count: 45312
Count: 58368
Count: 0
Count: 0
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 177
Time Indication: 0
Date: 2014.01.04
Time: 00:09:58
Freeze Frame:
Count: 3
Count: 12
Count: 4608
Count: 195
Count: 45568
Count: 58112
Count: 0
Count: 0
00150 - Plausibility Brake Booster System
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 177
Mileage: 185594 km
Time Indication: 0
Date: 2014.01.04
Time: 00:09:47
Freeze Frame:
Count: 3
Count: 14
Count: 12288
Count: 398
Count: 45568
Count: 58112
Count: 0
Count: 0
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 AJ HW: 5K0 907 044 AJ
Component: Climatronic 130 0305
Revision: 00002001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 73E5B5AADA7402DAAD-8026
No fault code found.
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 B HW: 1K0 937 086 B
Component: BCM PQ35 M 020 0358
Revision: 00020000
Coding: 40180A3A98251AC0440000801400812445510088436D896064 8000000000
Shop #: WSC 52010 981 94061
VCID: 2F6D79DA7EDC663A09-807A
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 09120 21 0501
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 140911 05 54 0403
Coding: 0330AD
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 A HW: 5K0 959 655 A
Component: AirbagVW10G 022 0507
Serial number: 003C3D051BTY
Coding: 00003136
Shop #: WSC 00028 028 00312
ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 387F42868392A18258-806C
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V U01 ----
Serial number: 38731246ZZZZZZZZZZZZ
Crash sensor for side airbag: front passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V U01 ----
Serial number: 2E761046ZZZZZZZZZZZZ
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 160D1749ZZZZZZZZZZZZ
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 2E27173CZZZZZZZZZZZZ
1 Fault Found:
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 185576 km
Date: 2019.08.13
Time: 22:27:31
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 853 0111
Coding: 0001004
VCID: 020BE06E5DCE3B52B6-8056
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 860 D HW: 5K0 920 860 D
Component: KOMBI H21 0029
Serial number: 00000000000000
Coding: 570B00
Shop #: WSC 00028 028 00024
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 2D5163D27CD0142A3B-8078
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 111208F2001448
Coding: ED807F06000202000003
VCID: 377D41BA468CAEFA51-8062
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 177
Mileage: 185576 km
Time Indication: 0
Date: 2014.01.03
Time: 22:42:13
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H21 0029
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 AG HW: 1K0 959 701 AG
Component: Tuer-SG 008 2042
Coding: 0004790
VCID: 73E5B5AA127402DAAD-8026
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 69 2501
Revision: 00H15000
VCID: 2C576ED68FCA1D222C-8078
1 Fault Found:
16347 - Control Module - EEPROM Error
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 1
Fault Frequency: 1
Reset counter: 50
Time Indication: 0
Freeze Frame:
Voltage: 12.25 V
PD
Temperature: 36.0°C
Speed: 50.0 km/h
Torque: 0.0 Nm
Torque: 0.000 Nm
Term 15 On
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 AG HW: 1K0 959 702 AG
Coding: 0005046
VCID: 74E7B6B6177A05E2B4-8020
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
Component: Tuer-SG 007 2009
Coding: 0000144
Shop #: WSC 00028 028 1012545
VCID: 7AFB988E351E7392EE-802E
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
Coding: 0000144
VCID: 7BF59D8A3A244A9AF5-802E
End-------------------------(Elapsed Time: 02:12)--------------------------
Buy every pirate China has to offer for cheap...and WIN!
Buy everything the original manufacturer has to SHOW YOUR SUPPORT!
its common on this abs modules al send you the longcoding tomorrow
Check this:
113b200d09260000881204ec90220001b000
113b200d09260000881204ec90220041b000
Please dear members push the button if my work was helpfull!
And reputation button(star)
Tefocm (3rd February, 2020)
