Results 1 to 3 of 3
Thread: DOIP SD C4
    Mar 2019
    Default DOIP SD C4
    WHAT IS DOIP SD C4?
    DOIP SD C4 = SDCONNECT C4 + DOIP
    The new SDconnect C4 (1:1 clone of the original) is able to work for DoIP.
    It's the only C4 that supports ethernet communication (DoIP).
    Have tested no issues on new Mercedes with DoIP.
    You don't have to install batteries for firmware update.
    No need worry about firmware damage in the update process
    Mar 2019
    sd c4 doip vs. star c6 vs. benz ecom vs. oem xentry diagnosis vci
    Name OEM XENTRY DIANGOSI VCI Benz OEM C6 Benz ECOM SD Connect C4 SD Connect C4 Plus DoIP Xentry connect C5 DoIP
    Image OEM XENTRY DIAGNOSIS VCI.jpg oem star c6.jpg benz ecom.jpg sd c4.jpg doip sd c4.jpg
    Feature With Dongle same look as the genuine c6 Good at diagnosis and programming Good at diagnosis and programming Work with original Xentry XDOS DoIP Enabled DoIP enabled
    Software compatibility Factory HDD/SSD only Factory HDD/SSD only Factory HDD/SSD only Factory HDD/SSD only/original software Factory HDD/SSD only/original software Factory HDD/SSD only
    Update By HDD/SSD By HDD/SSD By HDD/SSD By HDD/SSD By HDD/SSD Free update by file
    Diagnosis Yes Yes Yes Yes Yes Yes
    SCN Coding Yes Yes Yes Yes Yes Yes
    Programming Yes Yes Yes Yes Yes Yes
    Xentry Yes Yes Yes Yes Yes Yes
    DAS NO Yes NO Yes Yes Yes
    EPC Yes Yes Yes Yes Yes Yes
    WIS Yes Yes Yes Yes Yes Yes
    SDmedia Yes Yes Yes Yes Yes Yes
    Star Finder Yes Yes Yes Yes Yes Yes
    PL73 Yes Yes Yes Yes Yes Yes
    DTS Monaco Yes Yes Yes Yes Yes NO
    Vediamo Yes NO Yes Yes Yes Yes
    DoIP Yes Yes Yes NO Yes Yes
    New Mercedes Yes Yes Yes yr2011- Yes Yes,till year 2019 Yes
    Old Mercedes NO YES NO Yes Yes NO
    wifi NO Yes NO Yes Yes NO
  3. The Following User Says Thank You to serenakong4328 For This Useful Post:
    ilok24 (27th November, 2019)
    Feb 2010
    whats the price ?
