    Aug 2018
    USA
    Default Opel Zafira y22dtr PSG16 p0606 and p1632
    Hi!
    I have Opel Zafira with pump malfunction.
    The MOSFET is changed(burned wire and trnasistor inside pump), but these errors don't go.
    Someone said that this may be a ground problem, as the ground to the MOSFET is burned.
    Any advice on how to repair will be appreciated!
    Jun 2013
    Maybe pump Is death?
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
    Aug 2018
    USA
    Quote Originally Posted by wbart View Post
    For sure pump is dead! I need to repair it.
    If someone knows where the ground points go, it'll be perfect.
    There is a guide for PSG5, but can't find such for PSG16.
    Aug 2012
    EU
    I have same problem with psg16,P0606 and P1632,car not start.I try connect diagnostic on the table,then this fault codes not get,if diagnostic via car obd,i get P1632 and P0606,I checked all powers and ground in the car,B+ ok,B- ok,Ignition ok.Same problem with two pump...
    sorry for me bad english.
    Oct 2015
    Default saab 1.9tid psg
    Hi, the same problem with saab psg16 is there any news how its ended?
    mexanico1971's Avatar
    portugal
    Guys did you find the problem for p1632 Injection pump ?
    My work is my life ART TECH GARAGE
