Results 1 to 7 of 7
    razvanrms's Avatar
    Sep 2015
    romania
    Default Mercedes C220 Delphi DCM3.2 need good solution dpf/egr
    Hi ! I need good solution ford DPF/EGR OFF Mercedes C220 Delphi DCM3.2 with ALL SENSOR DISCONNECTED !
    A 646 150 19 72
    A 005 446 16 40
    HW 50.06
    SW 07.07
    i atached full back up with K-TAG .
    Thanks in advance !
    golf110tdi's Avatar
    Apr 2016
    EU
    You can try this file.
    Pass in PM.
  3. The Following User Says Thank You to golf110tdi For This Useful Post:
    razvanrms (19th August, 2019)
    razvanrms's Avatar
    Sep 2015
    romania
    Thanks bro !
    After write your modified file ... the car is still in limp mode with some dtc ...
    2256 - B60 ( EXHAUST BACK PRESSURE SENSOR )
    22f8 - M16/5 ( THROTTLE VALVE ACTUATOR )
    23e8 - Check component B28/8 ( DPF differential pressure sensor )
    golf110tdi's Avatar
    Apr 2016
    EU
    Ok. I can rework the file with remove this faulty and upload file.
    2256
    22f08
    23e8
    golf110tdi's Avatar
    Apr 2016
    EU
    Test and report.
    The same password
  7. The Following User Says Thank You to golf110tdi For This Useful Post:
    razvanrms (20th August, 2019)
  8. #6
    razvanrms's Avatar
    Sep 2015
    romania
    Bro , thank you very much for your time ... but after write your second file , car is in limp mode ...
    errors - 22f8 - M16/5 (Throttle valve actuator )
    2383 - M16/5 (Throttle valve actuator )
  9. #7
    golf110tdi's Avatar
    Apr 2016
    EU
    Test and report. To many faults to remove.
    The same password.
