Results 1 to 10 of 10
    May 2017
    Default 1.8T Deatcode Problem ME7.5
    Got problem with this me7.5 and checksum (didnt have 95040sum to correct).
    Problem should be deathcode in epr?
    After write tune car runs ~ 20min and than didnt start up again and show errors like P0601...
    Somebody here who can fix it? With correct checksums?
    Nov 2014
    Quote Originally Posted by Lambda1 View Post
    Fix 33 to 00 in first línea EEPROM and test
    Enviado desde mi Aquaris_A4.5 mediante Tapatalk
    May 2017
    need chks after this in eeprom... I dont have tool for doing this in epr.
    Nov 2014
    I don't like how my fvdi makes those chk. Directions are 1C and 2C. Values are 33,test to 00 if It doesn't work I can send you my fvdi correction. Regards
    Nov 2014
    Test it mate.Regards
  6. The Following User Says Thank You to goyodesanctis For This Useful Post:
    Lambda1 (16th August, 2019)
    a500tut's Avatar
    Jun 2017
    Belarus
    Try and report You flash file don't have checksum...
    If I helped you, click thanks and reputation
    May 2017
    Thanks mate for chks in file, will re calculate to confirm by hand because found adresses for.
    Flash chks should be okay since first post...
    Nov 2014
    You are welcome. If I helped press thx please
  10. #9
    Nov 2014
    Quote Originally Posted by goyodesanctis View Post
    My ols says error for all chk It has 73
  11. #10
    May 2017
    74 (if you start with 1) + Patch ... its because you dont have original data... if you had original and also import tuned winols will show you they are fine .
